SoftСam keys
Тут обсуждаем и делимся свежими ключами разновидных систем условного доступа
SoftСam keys
LaLiga TV 10°E 11346 H 27500
Скрытый текст
Для просмотра скрытого текста необходимо быть авторизованным пользователем.
extraneous
Новый Пользователь
Новый Пользователь
SoftСam keys
Непрочитанное сообщение extraneous »
Бисы викард и азбокс. не открывает каналы
[*][filter]
active = 1
name = dvb
type = pre
rule = caid=0500;ident=040620,060C00,060A00,041200;accept=ntv
#rule = caid=0500;ident=040600,050100,040610,050A00,050B00;reject
#rule = caid=0500;ident=043800,042700,000068,041700;accept=hb
#rule = caid=4AE0;ident=15;ident:=0;accept=tk
rule = caid=2600;accept=biss
rule = caid=4AE0;ident=0,11,15;ident:=0;accept
#rule = accept
rule = reject
[reader]
active = 1
name = biss
type = emubiss
caid = 2600
file = /PLUGINS/Keys/SoftCam.Key
debug = 3
[reader]
name = ntv[*]
[*]08:54:39.928 DVB0[OpenXCAS]: channel change: sid = 17ed, vpid = 17ee, apid = 17ef, 50, 11766000 Hz
08:54:39.932 DVB0[OpenXCAS]: program_number 17ED demux_id: 0 demux_index 0 ca_mask: 1 program_info_length: 36
08:54:39.934 DVB0[OpenXCAS]: stream type: 1b (H.264/14496-10 video (MPEG-4/AVC)) pid: 17ee length: 22
08:54:39.936 DVB0[OpenXCAS]: stream type: 03 (11172-3 audio (MPEG-1)) pid: 17ef length: 17
08:54:39.938 DVB0[OpenXCAS]: found 1 ecm pids and 2 stream pids in PMT
08:54:39.945 DVB0[OpenXCAS]: Register ECM filter 2600:000000, PID: 1FFF
08:54:39.948 biss: ECM81 (2600:000000/17ED.0) from DVB0[OpenXCAS] inserted into queue
08:54:39.950 DVB0[OpenXCAS]: found 0 emm pids in CAT
08:54:39.956 biss: ECM 2600:000000 11 bytes 81 70 08 17 ED 1F FF 17 EE 17 EF
08:54:39.958 biss: DCW 1A 2B 3C 81 4D 5E 6F 1A 1A 2B 3C 81 4D 5E 6F 1A
08:54:39.960 biss: status = 2, DCW 1A 2B 3C 81 4D 5E 6F 1A 1A 2B 3C 81 4D 5E 6F 1A
08:54:39.962 biss: 2 ECM81 (2600:000000/17ED.0) for DVB0[OpenXCAS] decoded (8/15/15 ms)
08:54:39.966 DVB0[OpenXCAS]: ECM81 (2600:000000/17ED.0) 'N/A' decoded by biss
08:54:39.970 DVB0[OpenXCAS]: write cw0 demux_id: 0, stream_no: 0
08:54:39.973 DVB0[OpenXCAS]: write cw1 demux_id: 0, stream_no: 0[*]
Благодарил (а): 2026 раз
SoftСam keys
Astra 4.9E
TEST-1 и TEST-2 на частоте 11747 V 30000
Скрытый текст
V.A.L.E.R.A.
Ресивер: Octogon SF4008
Благодарил (а): 278 раз
SoftСam keys
Непрочитанное сообщение V.A.L.E.R.A. »
SoftCam.Key By V.A.L.E.R.A. 13.11.2018
[PowerVu]: NBCU E! Entertainment (68.5°E) New!
[Irdeto]: Bulsatcom (39.0°E) New!
[BISS]: FEED HD MBC (21.6°E) New!
[BISS]: SRTV feed (16°E) New!
[BISS]: TEST A, TEST C (4,9°E) New!
[BISS]: ESPN Caribbean, Syndication (15°W) New!
Octagon SF4008, OpenATV-6.3, мотоподвес TRIAX TD110, Inverto Black Ultra : 90E-15W/ +90E, 85E, 75E, 60E, 56E-55E, 53E, 36Е, 31E, 19E, 13E, 5E, 4W
Змей
SoftСam keys
Непрочитанное сообщение Змей »
Доброго всем дня суток, я так понимаю из серьезных пакетов на ключах кажут лишь болгары с 39е ? хотел проверить да че то не смог поймать сигнал (
parahat87
Новый Пользователь
Новый Пользователь
Ресивер: XDSR420HDAVANT
Антенна(ы): 13,42,85,56
SoftСam keys
Непрочитанное сообщение parahat87 »
Привет! Админ мне нужен висс кулич для xdsr 420 avant мой градус 13,85,56,42,31.5 аславнрй нужен идман Азербайджану!!! Пожалуйста!
