Транспондерные новости 31.5°W - Intelsat 25
- wellikan
- Site Admin
- Ресивер: Dr.HD 1000 Combo, Denys H.265, TBS 6903
- Антенна(ы): Parabola 1.4м
http://www.flysat.com/is25.php - http://www.lyngsat.com/Intelsat-25.html
TM 2 (ORTM 2) вернулся на 12344 V 2121 FEC 7/8, DVB-S/MPEG-2, открыто
- stephan94
- DX-er
Доброе утро.
С 13 апреля на этом спутнике действует новая частота. 12335 V 6427 7/8
Он заменит две старые частоты.
Старые частоты будут отключены 19 апреля в полночь.
Из Баварии новая частота немного слабее старых.
это ограничение на получение.
- flie
- Зарегистрированный Пользователь
- Ресивер: TBS5927
unfortunately signal is barely seeing from here
0.90m Geant mesh dish ,1.21m Atlas (testing...)
TBS5927,TBS5521,TBS6903X,SKYstarUSB HD
- satesco
- DX-er
- Ресивер: DM920 UHD,Vantage HD 7100 S
- Антенна(ы): 150cm
@flie,you do not need to scan the entire satellite band.It would be good to look at a satellite list,let's say,FlySat,and see which band is using that satellite.Only a few positions(19.2E,13.0E,0.8/1W) are used the whole Ku-band.With Crazyscan you have the possibility to limit the bandwidth of the scanning according to your desire.If screenshots are only for you,there is no problem,but if you post for others,it is advisable to do what I told you above.Most of us are interested in the frequencies that you found.The easier we read the spectrum,the signal found,so much the better.
regards
regards
- flie
- Ресивер: TBS5927
thank you very much satesco , malval450 talk about this too
my scan now
my scan now
- dreamsat
- DX-er
- Ресивер: TBS 6983, TBS6522
- Антенна(ы): 2,20m, 3,70m
12334 V 6426 7/8 New " Energy TV "
regards dreamsat
regards dreamsat
- dreamsat
- DX-er
Carrier on 12319 V 6500 . I have to try again with 3.7m.
regards dreamsat
regards dreamsat
- dreamsat
- DX-er
now is a Lock at 12319 V 6500 7/8
regards dreamsat
regards dreamsat
- dreamsat
- DX-er
two new transponder with unknow modulation
regards drteamsat
regards drteamsat
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 0 гостей
